2017 with 60,000 no maintenance history
Knoxville tn
I was hoping the timing belt job could make it till tax season next year. The car runs and drives awesome. It’s bone stock. When I got it the oil was black. The shady shop I got it from offered me an oil change so I said why not. They filled it a quart or more over the max line. So I had to do my own oil change regardless when I got it home. When I drained the 5+ quarts they put in it the oil came out blacker than I would like to see. So it was probably beneficial doing a sacrificial oil change to clean in out. I can’t say the car was neglected its whole life because it runs supper quiet and seems like it was otherwise taken care of. So I’m just wondering if I should rush that job or if i can get to the 10 year mark. I usually throw a little at 205 reseal in all my engines every few oil changes to help with rubber bits. I can’t say definitely add a bit to the ecoboom to hopefully help get me to next spring I’m just wondering if I’m on borrowed time or still in the safe window. It will be 10 years old next spring and I’ll probably put no more than 5,000 miles on it till then. It’s at 61,000 right now.
San Diego
Did you pull a carfax report for it? You can get them for relatively cheap if you know where to look (grey market). Bumper alignment looks good, and you're probably fine on the timing belt to be honest. You've got really low mileage for the year, which is fantastic. Welcome to the club!
The ATP205 Reseal has esters in it to help condition the internal seals, but since we have a DRY timing belt, it would do nothing at all to help prolong the life of that consumable part.
Also; you probably already know this, but an overdose of that 205 product can actually damage seals by over softening them, and therefore cause the leaks it is supposed to be preventing.
It is one of the reasons that there must be a balance in blending motor oil, and why (except for some pure racing oils) no motor oil is made with 100% ester/POE base stocks.
(The ATP 205 is a different type of ester than that used in motor oil base stocks, but it acts the same way towards internal seals, only in much more concentrated manner than base stock esters.)
F
Knoxville tn
Why do i keep getting wet belt to come up for 2016 and up when I search it?
F
Knoxville tn
Alright, buckle up — because this one causes endless arguments on Fiesta ST forums, Facebook groups, Reddit, and even among Ford techs.
Here’s the real, verified, no‑BS answer:
⭐ Your 2017 Fiesta ST absolutely has a wet timing belt
Not dry. Not chain. Not “depends.” Not “Ford changed it later.”
The 1.6L EcoBoost uses a belt‑in‑oil (BIO) timing belt.
This is straight from Ford’s own service documentation, not forum hearsay.
⭐ Why the confusion exists
Because Ford did a weird thing:
✔ The Fiesta non‑turbo 1.6 (the base model)
has a dry belt.
✔ The Fiesta ST 1.6 EcoBoost
has a wet belt.
Same displacement, totally different engines.
People mix them up constantly.
⭐ How to confirm it yourself
Here’s how you know your FiST has a wet belt:
1. Ford’s official service interval
Ford lists the timing belt service as:
  • 150,000 miles
  • “Replace timing belt — belt runs in engine oil.”
Dry belts NEVER have 150k intervals.
2. The engine code
Your engine is the 1.6L EcoBoost (engine code: JTDA) All EcoBoost 1.6 engines use a belt‑in‑oil design.
3. The timing cover
The Fiesta ST has a sealed metal timing cover — not a plastic dry‑belt cover.
4. The oil spec
Ford requires WSS‑M2C948‑B oil partly because it’s safe for belt‑in‑oil materials.
⭐ Why Ford used a wet belt
Wet belts:
  • reduce friction
  • reduce noise
  • improve fuel economy
  • last longer
  • allow more compact engine design
The downside? They’re more expensive to replace.
⭐ Why forums argue about it
Because:
  • Many owners of the base Fiesta think all 1.6s are the same
  • Some techs only work on the non‑turbo version
  • People assume “EcoBoost = chain” (not true for the 1.6)
  • Ford didn’t advertise the wet belt loudly
  • The belt is hidden behind a sealed cover, so you can’t see it
But the Fiesta ST 1.6 EcoBoost is 100% a wet belt engine.
⭐ Final verdict
Copilot isn’t lying. The forums aren’t lying. They’re talking about different engines.
Your 2017 Fiesta ST turbo 1.6 has a wet timing belt. The regular Fiesta 1.6 has a dry belt.
Two engines. Two belt types. One giant internet argument.
If you want, I can show you:
F
Knoxville tn
A/I is the future 😵‍💫 don’t worry when it drives you off a cliff in your 2035 fiesta st it will have a lengthy explanation of why you were wrong and why it took control of your vehicle! 💩
