stuntdoogie
NYC
There are certainly more tire options available in that size lol. I'd really like to go wider(either 215/45 or 225/45) but the selection of tires available is very small.
Keep in mind the car will be daily driven, mostly highway miles, might try out some autox this summer as well.
Lowered on mountune with anything wider than 205 will rub for sure.
For the record, I can deal with a little bit of rubbing. My last car would rub/scrape basically everywhere because it was very, very low. Lol.
I'm not going in that direction this time around(obviously). I'd actually like to enjoy driving it [emoji12]
My wheels are 16", not 17".
I might stick with my original plan of going with 215/45/16.
shouldbeasy
Calgary, AB, Canada
Completed a decent road trip with the 215/45/17's and I can say they feel a bit more stable at high speeds (180km/h) and the car itself feels a bit more planted. That's all subjective though.
Doesn't rub, although I did take a hammer to the rear of the rear wheel well liner to pound it back a bit. With my snow tires (same size but probably measure larger) they rubbed and so I knew I had to do a little something.
I'll post up some pictures right quick.
Carson City
Doing the research right now on running Maxxis RC-1 245/40/15 on 15x9 wheels right now:)
10" wide is better but none I can find will fit and I have 15x9 wheels which would be better with 225 wide tires except I will soon have much more power, EFR DHM turbo kit and want more tire on the ground up front.
Kip2MyLou
Gaithersburg
I'll definitely be going 16s next year and either 205/50 or 225/45. But I'll be on stock suspension so I know for sure those choices won't rub.
Las Vegas
Thought id chime in on my setup....
Rota Grid 16x7 e42, 205/50/16 bfg sport comp 2.
Bc coilovers dropped 23 3/4" front and 24" rear. Measurement is from center of wheel well to floor. No rubbing whats so ever. Im even considering lowering another 1/4".
Sorry if I missed this but I've been looking for this setup for a while now, are yours 4x100 or still 4x108?
Izzy
Houston
I'm going to be running these exact wheels in the above mentioned specs. Just really trying to find a wider tire that will fit even if I have to run spacers.
Las Vegas
I found some on ebay but the picture seemed a little sketchy and then I found a website for a store out of CA that says they have some so I'll call tomorrow and hopefully place an order then get some tires.
