rastok
Thread Starter #841
Exshaust wrap wrapped intake!!
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
dyn085
Exshaust wrap wrapped intake!![/IMG]
That's the exact opposite of what you want to do to an intake because header wrap is designed to hold heat in. You'd be much better served by removing it and replacing it with the reflective tape designed to keep heat out.
Exactly! The 2 hp you gained from that injen intake was just lost and then some probably
On the other hand, the wrap could keep engine bay heat out of the intake tract... Insulation works both ways. Just saying... ;-)
-: FB :-
rastok
Thread Starter #845
i thought about it this way around hahaha
dyn085
-: FB :-
No, it doesn't. Header wrap is designed to soak up and hold heat. That's why an engine bay is cooler when it's installed on a header. When it's installed on an intake it soaks and holds the engine bay heat, transferring it directly to the intake tube.
Conversely, reflective tape designed for intakes does exactly what it sounds like-it reflects the engine bay heat from the intake tract, allowing for less transfer from the tube to the air passing through it. They are separate products for a reason, and it's not because it's a conspiracy to get more money out of enthusiasts.
Yeah, I guess you're right. Different kinds of insulation do different things...
-: FB :-
Mountune springs and my OA badges installed while I'm out of town. As much as I am enjoying our vacation, can't wait to get back and see it in my driveway!
TheStig
This is why motocross bikes have gold reflective tape or "tank blankets" on the bottom side since they are inches from a hot motor. You do not want superheated fuel going into your engine, same goes with air.
Header/Exhaust manifold wrapping is as mentioned above to trap the head inside the exhaust system to expel it, or for us turbo guys, get the most heat and "bang" to the snail.
If you put hot air/fuel mixture into your engine, you're gonna have a bad time.
Torsion spring snapped on the garage door last night. So tonight the kids sleep outside :(
rodmoe
Not right now but from this past weekend at the track with DHM .. Turned out to be a good learning experience for a couple of us with track offs and missed shifts LOL
Thoughts are with ya guys at DHM..
stuntdoogie
Any gopro vids?
Kip2MyLou
Thoughts with them? Everything okay?
