Harvick
I'm going to start composing a list of lowering springs available for the Fiesta ST. Let me know if you guys find anything and I can update the first post.
Ford Racing - Price $289.00
Part# M-FR3-FA
Front: .5"
Rear: 1.0"
Eibach Pro Kit - Price $227.00
Part# 35143.140
Front: .8"
Rear: .7"
OE rate: 30 N/mm (172 lbs/in)
Pro-Kit progressive rate: 19-30 N/mm (109-172 lbs/in)
H&R - Price $206.00
Part# 51641
Front: 1.2"
Rear: 1.0"
Vogtland Sport Springs - Price $229.00
Part# 953113
Front: 1.4"
Rear: 1.4"
Apex Suspension System - Price $189.00
Part# NA
Front: 1.5"
Rear: 1.5"
Apex_lowering_springs_for_all_ford_fiesta_focus_st_models_available_at Pumaspeed_performance2.jpg
Mountune - Price $269.00
Part# 2364-MSK-BA
Front: 1.1"
Rear: .8"
Front OE springs 172lbs/in 181lbs/in
Rear OE 137lbs/in 144lbs/in
koozy
good idea, it would also be helpful to have part numbers or links to the items.
LT Berzerker
Definitely need some pics of the cars running the different spring options :)
iso100
I'm confused. What does the OE stand for when listing spring rates? Why does the Mountune listing have two sets?
JPGC
Fiesta ST Lowering Springs Thread
OE= Original Equipment. They are comparing their spring rates with the OE spring rates. BTW, the mountune springs, at least for the 4 door are made by eibach for mountune. Mountune has two sets, one for the two door FiST and one for the four door FiST.
airjor13
Huge fan of the H&R springs, for $200 shipped the price can't be beat. Install took literally 1 hour flat, the rears about 10 minutes, the fronts 50 minutes including beer and smoke breaks. All you really need is a solid spring compressor and thats it, this is really the easiest most straight forward lowering spring install I have ever done!
I was able to do it without a compressor. I used 4 zip ties on each strut before I removed the top hat and they were strong enough to keep it from popping violently.
airjor13
Wow, but I wouldn't recommend your zip tie method, seems a little dangerous to say the least.
Is the Ford factory M-FR3-FA kit the standard handling pack on the ST, and an upgrade for non ST Models, or is it an upgrade for the ST as well?
That seems like a really reasonable price for a complete suspension from FoMoCo with dampers and all....
http://www.steedafiesta.com/parts/ford-racing-fiesta-handling-pack/
http://www.fordracingpartsdirect.com/2011_2014_FORD_FIESTA_HANDLING_PACK_p/m-fr3-fa.htm
http://www.summitracing.com/parts/fms-m-fr3-fa
http://www.roushyatesparts.com/Handling-Package-p/frp-m-fr3-fa.htm
Harvick
Harvick
Thread Starter #18
[MENTION=1682]propergarage_ST[/MENTION] Here are some pics with the Mountune springs.
[MENTION=6]Harvick[/MENTION] It looks good, def lower, I was hoping for a tad more front end rake. hows the ride quality compared to stock? noticeable?
