BoostBumps RaceRed Build Thread
Status
Not open for further replies.
BoostBumps
BoostBumps
Thread Starter #221
Awesome work, Tom! That CP-E does look next level compared to the other options currently available!
Thanks Tom! I am extremely pleased with the overall design and quality....
just read through the build. great job, sick car![perfect10]
Thanks!
gabe
I'm curious to know more about this intake. Anymore news or details???
pm .e if you don't mind
no-pistons
BoostBump's RaceRed Build Thread
I like that snorkel! Great idea, Boostbumps. I need to build me one of them.
Great build. It was a nice read and gave me some ideas.
I was curious--any particular reason why you opted for recirculating the OCC back to the manifold rather than VTA? The breather cap is basically serving as VTA, so maybe it's not necessary to worry about venting the catch can to atmosphere, as well. Nevertheless, VTA OCC seems like the safest option from a carbon build up standpoint.
BoostBumps
BoostBumps
Thread Starter #227
thank you...
Connecting the line from the IM to OCC provides much greater efficiency in "pulling" excess pressure from the VC under vacuum conditions...The breather CAP is just used as a redundancy which should help reduce pressure further...I installed the OCC moreso to provide for cleaner ignitions and not as much concerned with carbon buildup...
thank you...
Connecting the vacuum line from the IM to OCC provides much greater efficiency in "pulling" excess pressure from the VC...The breather CAP is just used as a redundancy which should help reduce pressure further...I installed the OCC moreso to provide for acleaner ignition and not as much concerned with carbon buildup...
Interesting. I think that might actually be the ideal setup. Under throttle, the PCV is closed, but the breather cap is open, allowing the pressure from blow-by to escape. Off throttle, the PCV opens up and the breather cap closes, coupled with vacuum from IM you are actually sucking out from the CC into the catch can. Is that correct?
BoostBumps
BoostBumps
Thread Starter #229
yes...that's basically the idea...just installed as a preventative measure....
Very Nice Build. I like how you provided all the OEM - upgrade comparison photos in the original posts in this thread.
BoostBumps
BoostBumps
Thread Starter #232
Great build. Thanks for this thread and all the info and photos.
Hey thanks! And very much appreciated...
Always eager to share information, insights, and experiences as many other members have here on our forum...
BoostBumps
BoostBumps
Thread Starter #233
Rally Innovations Front Splitter
Installed Rally Innovations new front splitter which now extends further than the previous version and also follows the front lines much better...
Easy Install...very pleased
Looks great man! Why'd you decide on this one? I thought I remember seeing you posting on a group buy for a carbon fiber splitter...
BoostBumps
BoostBumps
Thread Starter #235
thanks! I am very pleased...
Its the same basic styling as the Bojix...This splitter is somewhat more durable which made of aluminum and powder coated and also its half the price....
Additionally Rally Innovations just modified the original design and this new one extends ~1" further and follows the "lines" much better than previous version..
Ah okay, cool! For the install, is it just self-tapping screws?
BoostBumps
BoostBumps
Thread Starter #237
Its very light and uses the existing mounting hardware / locations as OE and also comes with 4 additional nut/bolt/lock washers which you do need to drill 4 holes to secure further ....The whole install took about a half hour max...very secure....
CanadianGuy
Looks good. Is that the 3 peice one?
Status
