New intercooler and boost levels
re-rx7
#42
Thecar will only produce as much boost as needed to hit its tq target.
razorlab
#43
Unless the torque target is unreachable by base WGDC+Compensations+ErrorCorrections.
Then it would just produce as much boost as that allows.
T
Thread Starter #46
Now I'm Lost and scared, that doesn't sound good?
razorlab
#48
Yes. What I was describing isn't necessarily a bad thing if that's the strategy being used.
Plus it's always better to undershoot than overshoot.
T
Thread Starter #49
[ohcrap] I do notice that when charge temps are lower I will get up to 19.5 psi. But I live in south Florida and it's still 90* here. I have a 2j race downpipe coming tomorrow, see how much of a difference it makes!
Kip2MyLou
#50
So before I go buying all these mods for my car, is something that's common or doesn't happen really that often? I plan on going stage 2 in the spring and would like to know what I'm getting myself into before hand.
re-rx7
#51
Damnt razorlab! You will be fine. Canned tunes are all the same. Just make sure you button down the hose clamps.
Kip2MyLou
#52
I'll be having my mechanic install it I trust him to do everything properly. And I was just asking. I always like to ask just to make sure.
re-rx7
#53
I hear you. I will be installing my Cobb FMIC tomorrow. I will post up my findings. I dont rely on boost numbers to tell me whats going on.
Kip2MyLou
#54
Sounds good. Post them in this thread if you don't mind. I'd like to see those.
dyn085
#55
Put your car in third gear and go WOT at around 1700 rpm. You should see max boost before 3200 rpm and still within most speed limits.
T
Thread Starter #57
So installed my downpipe today
Cobb is showing two codes
Ecu. And
Po18d...
Help!
koozy
#58
Ecu. And
Po18d...
Help!
do you have an Accesport? and if you do what map is loaded? The Cobb Stage 3 map is designed to accommodate the downpipe.
T
Thread Starter #59
No more codes. I forgot to plug a sensor back in lol thank you
