Avant Garde m240 question and help needed
T
Thread Starter #21
More tire on the ground
T
Thread Starter #23
Yes on vogtland springs
T
Thread Starter #25
It probably will rub :/ but I hope not lol
rooSTer
Oh yeah it'll probably rub in the front with 215..needs more low in the back though haha. What kind of mud flaps is that?
Roll your fenders some and it should be good... a 215/40 is not much bigger than a 205/40. It's only a 1/2" taller. and .3" wider... So not much of a difference.
T
Thread Starter #28
Haha I know! And they are the universal rally armour ones I made to fit lol
Would it be best to order these wheels in a +40 offset since the need for the 5mm spacer to fit effectively makes it a +35 offset? I know its only a 5mm difference but it seems it would sit flusher with the fenders after a slight roll/pull instead of such extensive work.
you know i was thinking the same thing? im thinking of buying these in a 40 offset and then getting the 5 mm spacer since we need to fit the brake caliper apparently? or maybe 43 offset
