Injector Seal tool install kits
Saint Pauly
Who has found a good Kit for installing the seals? It will be on a nostrum double sealed injector. I know if you pull them...They will need/should be replaced. Let me know what any of you use and p# or links if possible.
Thanks
Saint Pauly
Thread Starter #2
Here is the Amazon Kit I Bought... we will see if it works well for double sealed injectors also. It says it works for Gm...Subaru and Ford GDI Injectors.
Here is the Amazon link too
RULLINE 34720 Injector Seal... https://www.amazon.com/dp/B0D6TMPYD2?ref=ppx_pop_mob_ap_share
S
sullybosco
Guest
Here’s a good option, especially if you’re working with an injecteur vw setup, the rebuild kit from Injector Shop for Denso Bosch style injectors includes upper and lower O rings, micro filter baskets, and spacers. If you tell me your injector part number, I can find an exact seal kit link for your setup.
