P219A Code
Spring, TX
Car has intermittently thrown a P219A: Aif-Fuel Ratio Imbalance
Any quick checks fixes common this one to look into?
No performance effect that I can tell. Only possible symptom is it's averaging around 27mpg, but I've been having fun with it too, so that likely contributes to the lower MPG.
JAMADOR
Spring, TX
Thread Starter #2
Seems to have resolved itself? Haven't scanned codes, but the CEL is off now after about 100 miles on a fresh tank of gas [Shell 87]
Last tank was Costco 87
Grsemky
Arizona
Try using premium gas.... I personally only put 91 in it, I live in AZ and get that California 91... My MPG averages 30.1 combined
JAMADOR
Spring, TX
So, a maybe symptom.
CEL returns on a full tank & seems to go away when it gets down to around 3/4 full.
Will verify over the next tank or two to see if that's consistent.
JAMADOR
Spring, TX
Not sure on the ethanol part.
Last 2 tanks have been Shell 87 from the same station. Would have to look, but think the 2 before that were Costco 87.
If the next tank does the same CEL from full to 3/4, I'll try a tank or 2 of 93 and see if that has any different effect.
Mesa, Arizona, USA
Change o2 sensors? I had a p219a issue and replaced upstream & downstream and it went away. It was just an underlying code and never actually threw the light, but just a suggestion
