- 2016 FiST - Modified
- $12k obo
- Local Pick-up; If need shipping, you pay
- PM me on here or email: ccm302@gmail.com
- Located near 29801
=== Engine ===
- Stock air box
- K&N filter
- Whoosh IC Hoses
- Whoosh Symposer Delete
- GFB DV+
- Whoosh FMIC
- AWR Pass Side motor mount
- Mountune'd - 4 tunes: High Boost (25psi), High Boost w/ Launch, Low Boost (5psi), Bad Gas
- New Timing Belt
- New NGK plugs
- Stock exhaust
- 120k miles
- Whoosh RMM
=== Transmission ===
- Mountune Short Throw
- Whoosh Tranny Cable Bracket Bushings
- AWR Tranny Mount
- Whoosh Shiftknob
- Suspension
- Whoosh 2-pt Trac bar w/ new Control Arm bolts
- Powerflex Rear Coil Spring Pads
- Koni STR.T - front and rear
- Eibach Pro
- Whiteline 22mm Rear Sway
- Aftermarket lugnuts (so you don't have to worry about them heating up & expanding)
- Firestone Firehawks - 205/40R17 - needs new rear tires - will be supplied at this price
- New Pads & Rotors
- Needs new battery, will supply
=== Exterior ===
- OZ Ultraleggera 17x7 - Bright Silver, stock wheels come with car
- Some paint chipping around antenna
=== Interior ===
- Recaro Seats - heated
- Replaced headrests w/ regular Fiesta ones, have Recaro headrests in storage - will come with car
- Tinted windows
- 3D printed coin holder drawer
- 3D printed throttle pedal spacer - equal w/ brake pedal
=== Other ===
- 2 Key FOBs
