Has anyone tried these headlights?
Toronto
I've been mulling those over for months. glad to see they worked out! what is their bulb type? I'm ordering a set after the holidays.
the Euro lights (oem and aftermarket) are H7 low beam, H1 high beam, and 7507 BAU15s for the turn signal.
One other potential concern about the knock-off or non-OEM lights would be the durability of the clear plastics. Many of those plastics over time start to beak down and suffer from yellowing, or/and cloudy/hazy lenses. (note: this is often caused or made worse by car wax)
pelotonracer2
NRH
Depends on the wax. I've been using Adam's Buttery wax forever and my lenses still look new.... 4 years later. Car has really never been garaged.
V_2
Murfreesboro
I've done a few retrofits with TYC and DEPO lights over the years with zero issues reported or on my own lights. Generic ebay lights I might worry about, though. YMMV, of course.
KnockOff
Menifee
Any pics of the light cut-off? That would be nice.
Toronto
No idea of the tyc versions have the same cutoff as the German euro, they are an ece mandated cutoff.
Here compared to my murano/corolla modified led retrofit.
Bear in mind these are still covered in a sheet of plastic wrap when the photo/test fit was done
Sent from my SM-G935W8 using Tapatalk
KnockOff
Menifee
Looks nice. No extra light going where it doesn't need to go.
Miami
#32
Cutoff is the same.
Did you have to contact them to combine the shipping cost? When I tested in my cart, it still shows as $65 for each.
Yes, send a message and they will reply with the correct amount invoiced.
zanethan
Charlotte
#33
Has anyone tried to open the TYC lights up? I'd like them if there weren't all chrome
Columbia
#34
I did see a FiST for sale recently at a dealership in NJ with these euro headlights. I would assume this means it got through their safety inspection and nobody minded the headlights. Maybe since the headlights aren't some eBay special with rainbow LEDs and are OEM (at least in appearance), they didn't even notice the missing amber reflector on the side?
Camden
#35
2014 Fiesta-Projector Headlamp Assy With LED RH (LHD) Part Number: 1895781
- 2014 Fiesta-Projector Headlamp Assy With LED LH (LHD) Part Number: 1895784
Here are the part numbers for left hand drive. if you email Wendy from the ford parts U.K. page they will ship you these for $550 and they normally come second day.
V_2
Murfreesboro
#36
They are sealed with permaseal,barely fit in an oven, and are just miserable to work with. But it can be done. Took me several hours to open both.
Toronto
#37
You mentioned in your build thread that you have DEPO brand lights, not the TYC. I have read elsewhere that the TYC is butyl not permaseal, although I still haven't done my retrofit so they mine are still new in boxes and I can't say for sure :(
V_2
Murfreesboro
#38
Mine were advertised as TYC, but I ended up getting DEPO brand shipped to me. I have done retros with TYC brand, though, and they are also permasealed.
I have my fingers crossed for your retrofitting sake that they are butyl, lol. Maybe you will luck out.
ron@whoosh
Vendor
Las Vegas
#39
You may have better connections that I
I can post my quote from Ford Parts UK that are 510 GBP which when paid through PayPal is over $700 USD
I buy the OEM Ford Parts from another source in the UK fro just a smidge less and charge only what I do because I need to ship them twice and shipping is $60 UPS due to the size and insurance needed for these lights.
I'll post the quote from Ford Parts UK if needed. I don't challenge posts often but $550 USD is not accurate unless we are talking about eBay non OEM Ford parts.
LILIKE16ST
Saltville
#40
Diode dynamics just came out with a high performance led headlamp for low beams that is designed for use I reflector housings like our stock housings and not for projector style. They're normally 150 I got them for 120 for the pair on Cyber Monday and it's a preorder they will ship Jan 12. Read up on them on their site I highly recommend for anyone looking for a nice light upgrade with no glare in stock housings and plenty of good looks and additional light to use. I've had issues with my hid and decided to just go this route as it would be better all around anyways in stock headlight housings. I will post pics when I get them in Jan and install them.
Edit* they are called sl1
