Register
User Tag List
Page 18 of 18 FirstFirst ... 8101112131415161718
Results 171 to 175 of 175
Thread: Stage 1 tune comparison
  1. #171
    Senior Member 330 Rep Points danbfree's Avatar
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Earned First 100 Posts Earned First 500 Posts Earned First 1000 Posts Earned First 25 Rep Points Earned First 50 Rep Points Earned First 100 Rep Points Earned First 200 Rep Points Earned First 1500 Posts and 300 Rep Points
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    1,924
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    330
    Quote Originally Posted by purityracer316 View Post
    idk I just loaded my e30 tune through Dizzy and not feeling much of a difference from 93 Stratified. Maybe I'll drive it for a few weeks and get some logs in.
    Strange, I made the same move, from Strat V4 93 to Dizzy e30, but with Dizzy 93 in between, but Dizzy e30 just blows away any 93 tune I've ever ran... to summarize the charts, it's a full 20 HP and anearly 50 torque more just running e30 over 93 and just spins my tires like mad in Sport mode LOL!
    '17 Magnetic - black wheels/red calipers only option - New Feb, '18.
    Tunes: Dizzy V2 e30 with Cobb TC at 3 as daily smooth tune, Stratified v4.00 93 octane with Stratified Optimal TC when e85 not available.
    Performance: Drop-in filter w/cold air shroud cutout, Whoosh crossover w/upgraded turbo inlet, silicone Symposer delete and hotside J pipe, TurboSmart VR2 EM plumb back DV, 18" Magnaflow glasspack muffler with 9" resonated DC Sports black tip, step colder NGK plugs gapped at .0275.
    Mounts/bracing: Torque Solutions 75a RMM, Powerflex Street engine side mount inserts, TB Performance Traction Bar
    Interior: Mojo Mfg short shift plate, Savanini ball shift knob, leather padded arm rest cover.
    To Do: Intercooler, Eibach springs, tint. Really, not much else :)
  2. #172
    New Member 28 Rep Points
    0%
    Rate Transaction
    Member #
    10267
    Medals
    Join Date
    Jul 2018
    WICHITA
    State
    KS
    Country
    United States
    Posts
    99
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    28
    Quote Originally Posted by danbfree View Post
    I changed my fuel mixture and its running a lot better. I think I was just getting use to the aggressive throttle with 93 Stratified that it just made it seem faster. I just have to do a few more logs and send it in to Jason at Dizzy.
  3. #173
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    1,924
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    330
    Yes, even with the linear option Stratified is much more twitchy under light throttle/tip-in, I find that the Dizzy tune makes the car itself feel more refined with how smooth it is but still very strong, on 93... Also for the e30, and how amazingly strong it is, this is with Regular accidentally being put into it, burning off some on Stage 0, then making e35 with 4 gallons of real e85 and room for 1 gallon of Premium.. How far off was your mix when mine feels amazing with a Regular base! LOL... Also, mine is just the flash with one time review, do you know if he can make changes to both the 93 and e30 based off logs from this mix? Does he even do many changes or just check for safety with the one-time option? If you know....
  4. #174
    0%
    Rate Transaction
    Member #
    10267
    Medals
    Join Date
    Jul 2018
    WICHITA
    State
    KS
    Country
    United States
    Posts
    99
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    28
    Definitely don't have an answer for that. He and I both saw that I was getting quite a bit of knock with the mixture I had. So luckily I had a gallon left of whatever mixture I had. I then filled up with 4 gal of e70 and the rest 91/E10. Most of the gas station around me have 91 with 10% ethanol(tested the Kwik Shop, Quik Trip and Cenex) . There's two E85 station. One has true E85(Jump Start)and the other one is E85 but tested at 70% ethanol(Kwik Shop). The 93 stage 1 tune likes it with no knock. So far I think the E30 tune likes this mixture according to the log as how I see it. I'm still a noob, but like the learning experience.
    https://datazap.me/u/slow15fist/4th-...-241-255-62-53
  5. #175
    0%
    Rate Transaction
    Member #
    9500
    Medals
    Join Date
    Feb 2018
    Tigard
    State
    OR
    Country
    United States
    Posts
    1,924
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Likes Received
    330
    93 tune likes the ethanol mix? You definitely do not want to go above e15 on a regular pump tune, you need the fuel pump tuned to deliver the higher amount of ethanol needed.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
