2 DR FIST SS brake lines
los angeles
Hey guys,
Has anyone ordered SS lines for their non USA fiST? Ordered from 2J racing and they sent me the
wrong lines and the wrong brand. They don't respond to exchange requests.
Talked to modbargains and they can't confirm that Stoptechs will work because Stoptech is a
USA based company and most likely won't test on 2dr versions.
Anyhow, Ill attach a few pics for ref. Basically the fronts and rears look the same length and
both have mid-line clamps
Cheers
olathe
Here are my front wilwood SS lines mounted I got from 2J on my USDM. They are on wilwoods so the caliper connections are different but the routing looks the same.
C
los angeles
Cool. The issue is that 2J sent me not only the wrong brand, but lines from a regular Fiesta which has short rear lines. Won't ever order from them again
because they just ignore emails to exchange the item for the proper item.
Are your rears the same length asyour fronts? Mine seem to be.
North West
This doesn't sound right. Try calling 2J Racing.
olathe
We all have bad experiences with vendors that most people don't. I am sure you can get it sorted out, they have been good so far in my dealings.
What brand of lines did you get, mine are wilwood and yes I think they are the same length front and rear but I have wilwoods on the rear which are designed to go on a regular fiesta. The calipers not mounted as far back as the ST brakes so they probably don't have to stretch as far. Here is a pick of my rear fitted.
C
los angeles
Goodridge
The rears are way too short. Here's a pic of the length difference on the rears. I think that yes -
your Wilwoods allow for a shorter connection. ps sweet brakes man. I was thinking about
the kit until I tracked my Fist and was super impressed with the stock brakes.
