2014 Ford fiesta St 1.6 ecoboost
D
Thread Starter #21
Might the problem lie with the battery current sensor? That's the expensive battery cable with the box on it that makes it cost $100.
Yes that's what I'm thinking it is
D
Thread Starter #22
Has anyone ever tried bypassing the battery current sensor or the battery monitoring system..
Can't see your attachments; forum says they don't exist.
I did notice the fuse in the diagram.
Was that fuse intact?
#29
Wires look suspect but I guess that's just from you unbundling to inspect for damage?
What's the deal with this little patch here?
D
Thread Starter #30
I never noticed that I just bought the car of a guy selling it for his son.
D
Thread Starter #31
That's electric tape
Adam-Moors
So I recently be came the proud owner of a 2014 ford fiesta St and I swapped the battery on with a new one and now I'm getting a U1007. Car just cranks and cranks but doesn't start up need help on how t ok rest bms with out scanner please thank you
Are you sure that you used the right battery?
D
Thread Starter #36
After installing new cable sensor.. nother happened it crank and crank and crank but a no start so I took everything off this morning and found out I was a 180 degrees out on my cams so I just fixed it and putting everything back together right now will let y'all know tonight how it goes say in a little bit
#37
I was just about to suggest that it was probably something unrelated. Curious how it previously started up at all though? It uses a belt and (presumably) tensioner but a slip... especially to that degree would quickly result with bent valves, possibly damaged bottom-end.
D
Thread Starter #38
Well u see it's funny u say that because when I first got this car back last year In july cylinder 3 piston had disintegrated inside so I have finally got around to fixing it now I have this problem
D
Thread Starter #39
I was lucky enough the it didn't mess nothing u inside and the cylinder way perfect
SteveS
#40
Wait. The car drove fine, the battery died so you replaced it. Then a battery cable. And a cam got 180 degrees out of timing? I'm not following how a battery and cable change affects the cams.
