Selling my 2017 Ford Fiesta ST with standard equipment. It has lots of upgrades and is tuned by Adam at tune+. Also have most stock parts to go with the car. I am the only owner of the car and have done all the work and oil changes myself. Oil changed done every 5-7k with 5-30w oil. Currently has 75xxx miles on it. Brakes and rotors changed within 5k miles, clutch and flywheel have about 3k miles on them and transmission has about 35-40k. No issues or check engine lights. I owe 5k on the car therefore the bank still has the tittle so if I sold the car we would have to go through your bank or wherever you would be financing the car. Currently located in Kingman, AZ but willing to travel most places in the US. I’ll be posting more pictures tomorrow and updating them as I get time.
Aftermarket Parts: vin: 3FADP4GX7HM135174
- Whoosh Hybrid Turbo currently installed - have original turbo
- Whoosh brand Intercooler boost hose kit installed - replaced stock hoses do not have original
- whoosh brand Hi-Flo hot side intercooler pipe installed - replaced original
- Turbosmart Kompact Shortie Plumb Back BOV installed - have original on stock turbo
- Turbosmart High Boost 11 PSI Wastegate installed - have original on stock tubro
- Dizzy Tuning Ethanol Content Gauge installed - can run on 91/E30 with current tune
- COBB Tuning Accessport V3 installed - Custom tune by Tune+ can switch back to stock tune anytime but stock turbo must be installed first
- whoosh motorsports V2 Fiesta ST HIGH-FLOW Turbo Inlet Elbow installed - have original on stock turbo
- whoosh motorsports Performance Radiator installed - have original radiator
- Swift Spec-R lowering springs installed - Drop specs: Front -1.1" / Rear -1.0" have original springs
- Cobb Cold Air Intake System installed - have original
- Cobb Front Mount Intercooler installed - have original
- Cobb Rear Motor Mount installed - have original
- whoosh brand Transmission Cable Bracket Bushings installed - have original
- Boomba racing SYMPOSER DELETE installed - have original
- Team Dynamics Pro Race 1.2 Alloy Wheels 16in 205/50/16 indy hawk tires installed - has TPMS sensor also have stock wheels with TPMS sensor as well and stock wheels have same tires 205/40/17
- Changed brakes and rotors within 5k miles
- Clutch and flywheel have about 3k miles on them and transmission has about 35k miles had to get transmission, clutch and flywheel changed due to trans failing
- Picture of dyno graph will be attached in link
