3J NXG Plated Differetial
J
Northampton
The retail is going to be 799.00gbp with the VAT over here. Without the VAT to you guys is 665.83gbp plus shipping which will be approx 60.00gbp
J
Northampton
this is a plated LSD
The strongest, most progressive and versatile LSD unit in the market place.
The 3J plate pack always run with 8 active surfaces, even in our lighter settings, giving maximum surfaces and surface area contact during use. Our new pre-load spacer helps generate the pre-load. Rather than just have the 2 or 3 settings of other units, we can 'fine tune' to particular pre-load settings complemented with our choice of ramps, to get the perfect LSD set up for you!
The bevel and planet gear pack has been designed to be the smoothest mesh, biggest and strongest tooth profile that we have ever been involved with. Eliminating the rattle, and excessive back lash of other units. With the added benefit of dual ramps, two in every unit sold. Dual Ramps that are available are 30/90, 40/90, 30/60, 45/45, 50/90, plus more by request.
Perth
interesting... what kind of transmission oil does this LSD require?
Does it make much noise?
