Am I crazy?
Pittsburgh
are these tires mounted correctly? all are stacked with the rim face to the left. shouldn't 2 of them be going in the opposite direction??
Nitto NeoGen
Stock Potenzas
AncaSTer, Ontario
If you turn two of the wheel faces the other way (as they would be on your car) two of the tires would also be the other way!
I believe both types are not unidirectional, but the outside is marked on the tire.
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
Both are asymmetrical, non-directional tires. Like mentioned above, there is an "outside" and, consequently, an "inside."
milkman42
Pittsburgh
I though asymmetrical tires *would* be directional?
Hijinx
Auburn, AL, USA
There's an outside (wheel face). If they were directional, they could only be sold left or right, specifically, being asymmetrical and all.
Sunnyvale
If they are directional they should be clearly marked. My BFG comps have a "Rotation >>" arrow, no chance in messing that up unless they weren't ordered correctly.
corpus christi
Lol I have the same tires. All is good, I thought they were on wrong too when they were installed.
