Another Oil Thread
California
What would you guys rather run in your usdm Fiesta ST 1.6l turbo? Castrol MAGNATEC or Castrol Edge 5w30? Currently running the magnatec, thinking of switching to Edge.
I guess "high mileage" costs more LoL. At <80k mine is definitely not high mileage.
Been using Castrol the entire time though. BP makes good oil. Had 327k on a previous engine and it was perfectly fine using their dino/mineral (not "high mileage") oil. (lost vehicle due to rust)
Don't know what their additive package is for their gasoline but it stinks and have gotten way less torque out of it, across multiple vehicles in the past. Haven't touched BP gasoline in >10 years LoL...
SteveS
Osage Beach, MO, USA
High Mileage probably costs a dollar or two more in a 5 qt. jug. But the extra detergency of a high mileage oil might not be bad in a DI engine. And the seal conditioners aren't a bad idea in a minimum 6 year old car.
The detergents can make sense. These turbo engines dirty the oil faster than anything I've ever owned prior.
I don't have any evidence of sludge or build-up... though all I can do is peep through the oil fill hole and look at my drain pan.
My (perhaps not valid) concern with prematurely swelling the seals is, reducing their useful lifespan.
(very vaguely related example - https://www.fiestastforum.com/threads/water-intrusion-issue-resolved.23553/post-512426)
Perhaps if I see some evidence of a need for it, I'll consider it. I think I'm just content with the non-mileage labeled product though.
Kind of an "if it ain't broke don't fix it" kind of thinking LoL...
XR650R
Eerie
I bought my car new, and did the peloton thing. Glad I did.
Just change it every 5000 with some good full synth.
I tried 5W-30 for 5000 miles. I lost 1 mpg. Went back to 5W-20 because it doesn't get hot here.
Every 5000. Full synth. Full stop.
They are both fine engine oils.
The Magnatec is a lower cost option if that is a factor for you, and will be just fine for <5K OCIs.
The Edge is a more highly additized formula, and might use slightly better base stocks than the Magnatec.
It would probably stand up to DI fuel dilution a bit better, especially if you exceed that 5K miles on changes, but it is what, about $10.00 more per 5 quart/liter jug(??).
