What would you guys rather run in your usdm Fiesta ST 1.6l turbo? Castrol MAGNATEC or Castrol Edge 5w30? Currently running the magnatec, thinking of switching to Edge.
I guess "high mileage" costs more LoL. At <80k mine is definitely not high mileage.
Been using Castrol the entire time though. BP makes good oil. Had 327k on a previous engine and it was perfectly fine using their dino/mineral (not "high mileage") oil. (lost vehicle due to rust)
Don't know what their additive package is for their gasoline but it stinks and have gotten way less torque out of it, across multiple vehicles in the past. Haven't touched BP gasoline in >10 years LoL...
High Mileage probably costs a dollar or two more in a 5 qt. jug. But the extra detergency of a high mileage oil might not be bad in a DI engine. And the seal conditioners aren't a bad idea in a minimum 6 year old car.
The detergents can make sense. These turbo engines dirty the oil faster than anything I've ever owned prior.
I don't have any evidence of sludge or build-up... though all I can do is peep through the oil fill hole and look at my drain pan.
Perhaps if I see some evidence of a need for it, I'll consider it. I think I'm just content with the non-mileage labeled product though.
Kind of an "if it ain't broke don't fix it" kind of thinking LoL...
I bought my car new, and did the peloton thing. Glad I did.
Just change it every 5000 with some good full synth.
I tried 5W-30 for 5000 miles. I lost 1 mpg. Went back to 5W-20 because it doesn't get hot here.
Every 5000. Full synth. Full stop.
The Magnatec is a lower cost option if that is a factor for you, and will be just fine for <5K OCIs.
The Edge is a more highly additized formula, and might use slightly better base stocks than the Magnatec.
It would probably stand up to DI fuel dilution a bit better, especially if you exceed that 5K miles on changes, but it is what, about $10.00 more per 5 quart/liter jug(??).
WOW!
I always thought that the Magnatec was less than any of their Edge series (and it was in the past, from what I remember!).
Maybe whatever additive they use in that stuff (titanium? tungsten? and more of it than in the Edge?) skyrocketed in price, hence the crazy difference??
Actually, further research shows that Castrol discontinued Magnatec in 2022. So any remaining stock is apparently being scalped by retailers. It was replaced by the more simply named Castrol Full Synthetic.
I have only used full synthetic in my car since new. I've used Mobil 1, Castrol Magnatec, Edge and currently High Mileage. All have been 5W20 as recommended. Still runs like clockwork approaching 114,000.
