ap not connecting/not found with the ap manager on my pc
ROCKYFiestta
hello anybody run into this situation? I connected my ap to my new pc (worked on my mac laptop before) but now it does not find it no matter how many times you reconnect or change usb ports. hopefully my ap didn't break or something.[V]
ROCKYFiestta
ROCKYFiestta
Thread Starter #2
I used the one that came with the unit from cobb and its not working I will try my kindle tablet cable next [sadpanda]
ROCKYFiestta
ROCKYFiestta
tried diff cables still wont connect [???:)][sadpanda][scratch][?|]
ROCKYFiestta
ROCKYFiestta
I will go to the store and buy a brand new high quality cable hope it will work I sent cobb an email. I even tried reinstalling the software on my pc and mac and neither worked [B)][xx(][unbelieveable][8]
ROCKYFiestta
ROCKYFiestta
well I tried everything I could so far I tried 4 diff cables I had at home I even tried my old tried and true NES og 80s cartridge trick (aka blowing into the unit lol) [unsurelaugh]
ROCKYFiestta
ROCKYFiestta
so far I tried it on my gaming pc Alienware I tried it on all 12 usb ports even the blue colored ones and nothing. so I went back to my old mac laptop where it worked before and now it doesn't work either. [sad][?|] worse case I will mail it to cobb if I have to and have them give it a go.
ROCKYFiestta
ROCKYFiestta
I tried everything on their website so far I even turned off my firewall and even added the allow the ap manager through firewall as they recommended but still the same results. so weird that it will power up but not connect no matter what I tried, it on 3 different computers as well 2 pc windows 8 windows 10 and on mac osx as well and same results. I will be definitely call them in person Monday to see what else can be done. [sadpanda][?|]
DEss
Is the unit powering up when you connect the cable? If so, it's likely not an issue with the cable. More probably it's a driver issue.
ROCKYFiestta
ROCKYFiestta
yeah the unit will power on to all the computers I tried but it wont connect to the ap manager/ it will not find it
I don't know how to change the drivers I already tried reinstalling the ap manager off their website but that didn't work and I followed their flow chart in regards to allowing the program through the firewall and other security measures.
ROCKYFiestta
ROCKYFiestta
wondering if this is the cause of the problem
Windows has stopped this device because it has reported problems. (Code 43)
its on the INTEL(R) Serial IO I2C host controller-a2e1
PCI bus 0, device 21, function 1
ROCKYFiestta
ROCKYFiestta
ok after removing the ap from the pc the above error cleared and now I am showing no errors in my control panel leading me to believe you are correct about the drivers on my computer.[:(!]
Hopefully your AP is uninstalled from your car. If it is installed, your OEM tune is stored on it and if it must be replaced you will lose the OEM tune, unless you have it backed up somewhere in addition to your AP.
ROCKYFiestta
ROCKYFiestta
I backed it up on my pc but It ended up being the cable itself Jason @ dizzy suggested I get a new cable that can transfer data and that worked out thanks everybody for the help and input [party][party][raceflag]
