Bilstein B14 PSS rear ride height problem
I recently installed b14 suspension kit on my 2017 and have been fighting the ride height issue in the rear. Both sides are sitting similarly at just under 12.5 inches from center of the wheel to fender. But my driver side is roughly in the middle of the adjustment perch and passenger side is maxed out on adjustment towards fully low. I have taken the shock out and checked compression to the bump stop. I re torqued the beam bushing. I reinstalled the spring to make sure it was correctly sitting in the perch on the top and bottom and no fix. I'd like to lower the car more but I'm maxed out on the passenger side. I'm not sure what more I can do to try and find the issue. I'm really hoping something in the rear suspension isn't bent as I just got this car
I'm guessing you already made sure you're on a perfectly flat surface? For example, my own parking stall looks suitably flat but then the car is parked in it the rear right wheel hub is about half an inch closer to the fender arch than the rear left one, but when we put the car on the lift, everything was even.
T
Yeah I did everything in a garage on a level surface 😢
Have you checked the height setting on the front shocks? If your fronts are showing the opposite height pattern, your corner balancing is way off and the car will be sitting heavy on one diagonal and light on the other even if it appears “level”.
The easiest way is to start by setting the two fronts at the exact same perch position. Then do the same with the rear, setting perches the same. Then drive the car a bit to let things settle and see how it sits.
T
I haven't measured the actual perch on the front. I installed all 4 corners with how they came in the box, they all looked to be around the half way on the perch. The reason I adjusted the right rear is when I measured the ride height it was drastically different than all the other corners.
Dialcaliper
The things that stuck out when I did my suspension:
- It takes a good 100+ miles of driving for things to actually start to settle
- From my corner weight estimates, the left side of the car is slightly heavier especially with the driver in the seat
- The B14 adjustment range is actually pretty limited when it comes to coilover adjustments so while it might look like a lot of the adjustment range, remember that 3/4” of adjustment on a 224lb/in rear spring is about 165lbs. You can settle the car that much just by you sitting in that corner.
