- Member ID
- #4208
- Messages
- 1,991
- Likes
- 459
I just did the same thing as [MENTION=4567]Ryephile[/MENTION] on my 2016. Pretty straight forward. Look at the "T" fitting come off the intake tube.
Disconnect the fitting and remove hose at that end, then follow the hose to the plastic tube below. Remove that end and take hose out.
Cap the "T" at the end that you removed the top connector of the hose from. Also cap the other end down below, be sure to use a worm clamp because it's pressurized.
The hose removed
And the part number of said hose (for those with 2016's)
The hose removed
