Can Someone Measure the Length Of Rear Lowering Springs?
Fusion Works
Fusion Works
Huntsville, AL, USA
That makes sense. They are almost double the rate of the ST springs.
The stock spring is 11.75in long.
Fusion Works
Fusion Works
Huntsville, AL, USA
Well in this case, the ST spring, it did lower the car and the spring rate was less than stock.
kevinatfms
Germantown
Where did you get that the rates were lower than stock? From what KW told me the ST springs are 144lbs/in out back. Stock springs are 143lbs/in for the early ST's and 137lbs/in in the later ST's.
Fusion Works
Fusion Works
Huntsville, AL, USA
I measured the one off my car at 111-117lbs/in. I didn't measure my stock one. Guess I can. The ST book for my 16 says 143.
KW/ST still hasn't gotten back to me with an actual rate, after I ask last week. I was told initially before I bought them they were 240/250. That is BS.
Fusion Works
Fusion Works
Huntsville, AL, USA
I just measured my stock rear spring and its comes out to 127lbs/in. Yay Ford for not getting the info updated.
Fusion Works
Fusion Works
Huntsville, AL, USA
