Check your catch cans folks!
haste
I'm personally interested how far my engine will go and what it will look like at its end of life with no catch can. I will be putting a catch can setup on the car when I put the new engine in though.
jeff
jeff
If you get one I highly recommend one with a drain valve. That way you don't have to remove it each time you drain it; instead, it takes mere seconds, just drain it each time you change the oil. Here's my vid from a few years ago...I was wrong about the oil smell on the breather cap btw, you only smell if you pop the hood and get right up on it.
View: https://youtu.be/9uCsqrId-fM
Mine also has a dip stick, easy to check.
