Clicking noise behind glove box
Jonno
Uk
Hi all, having a clicking issue behind glovebox approx twice every 10 seconds, seems to be from the bcm but the vehicle has had an aftermarket Immobiliser fitted could this be an issue aswell ?? Any advise or updates would be great !
Capri to ST
CHAPEL HILL, NC, USA
A likely cause is a blend door actuator. They control different aspects of the HVAC system: where the air comes from, temperature, and fresh or recirculate.One of the three is behind the glove box. The gears in them strip out and they make a clicking sound when they try to turn. They do normally click faster than that, but that still strikes me as the most likely cause. There's a long thread covering all aspects of that, and here's a link to it-
https://www.fiestastforum.com/threa...cking-sound-part-numbers-video-install.22458/
J
Jonno
Uk
I’ve heard of that issue before however I think it’s a slightly different noise, have a wiper delete, recon this might be causing it due to rear wiper not being visible to bcm
Jabbit
New England
Check your stalk, sounds like you are triggering the ear wiper relay.
