Clutch Pressure Bleeding From the Top vs Bottom
FiestaSTdude
Ive used the motive pressure bleeder twice on my clutch and it’s fine. It does push fluid it through the brake fluid reservoir. From what I understand (could be wrong here) you bleed by the bottom at the slave cylinder when the system has no fluid to begin with, eg. you just changed the clutch.
