Clutch to Floor
JAMADOR
Spring, TX
Thread Starter #21
Good to know. Will plan on doing spark plugs [already in hand], coolant & brake/clutch fluids once we get past the school schedule chaos we've got right now.
Houston, TX
It's probably your slave seeing you're at 100k. Mine started going bad at 98k and totally failed at 104k completely unusable. Do you hear any noises when you have the pedal pushed in? I heard a whirring noise for those few K miles before it failed. Ended up replacing mine myself so if you need any pointers hit me up!
My failed slave: YouTube
Houston, TX
And for bleeding I don't like getting under my car so I just remove the air box and access the bleeder from there. Suck the fluid out of the brake fluid reservoir, then fill your syringe with fresh fluid and push it through the bleeder valve, repeat 3 times. I used this it fits our valve perfect
JAMADOR
Spring, TX
Thread Starter #28
Thanks, missed these earlier. Will look those up.
No noises from the clutch/TOB, and it hasn't stuck to the floor in the past 2 days [fingers crossed].
What would you rate the DIY, difficulty-wise? Does the trans need to come out, or is there room the split it & squeeze in?
Houston, TX
#29
The trans must come out. I'd say it's simple but hard work. Definitely doable yourself as I had no help. You'll need a transmission jack with a strap and make sure it can tilt in all directions as getting the trans back in is the hardest part.
Take a look at the shop manual here to see what the job entails. Full shop manual
http://sluggyjunx.com/auto/2014_Fiesta/Service Manual.htm
If you're looking for someone who can do the job for you at a reasonable price and who knows these cars hit up Francisco Olivares on FB. He's South East Houston but I think he might do mobile work too if you got the space
JAMADOR
Spring, TX
Thread Starter #31
Thanks again, posting on mobile but will look at the FSM tomorrow at work.
Trans put top or bottom? No access to a lift nor a high lift jack.
Last FWD trans I was involved in pulling was an Escort in college. We never got it to mate back up properly, lol. No idea what happened to that car.
Houston, TX
#32
Trans is dropped out the bottom. It was really difficult to align the transmission but with a transmission jack that allows tilt and rotation with straps it's definitely doable by yourself. I used this one from harbor freight. All you gotta do is align the dowel pins and bolt holes. Takes time and patience adjusting several times with the jack and eventually getting it in. I'd highly recommend getting some nice ratchet straps to hold the transmission on the jack as the 4 pegs don't do a good job and get in the way
The lift definitely helped me out a ton but I had to drop the car to the floor to use the transmission jack anyway. it honestly would've been doable from underneath if you had the patience.
Houston, TX
#33
Removing the transmission was very easy. I brought the lift down to ground level and removed the last remaining bolts holding the transmission. Laying on my back I brought my knees up to support the transmission while pulling it away from the engine. Brought it down to my chest and rolled it off to the side. Installation took a few hours as I first tried without a jack. Once I got the jack it took me 15 minutes of fiddling
