Cobb AP Firmware / OTS maps / AccessTuner Race - Updates
BoostBumps
BoostBumps
Arizona
Thread Starter #22
You've got it! There was a previous bug in the XML that prevented the row from being edited. We corrected the issue and cleaned up the table. From what I've seen the vehicle was fueling properly in that condition and generally kicked over to power demand fueling before allowing the last row to be active.
Cheers,
-Braden @ COBB
Hey much appreciated and thanks for clarifying the reason for the minor update for us Braden!
And I see that the Power Demand Fueling table in the OTS maps are initiated only when accelerator pedal position is >90%... correct?
Any idea as to when the AP auto-off firmware update is going to be released?....I use my AP daily as a 6-way monitor / gauge and it will be very nice to finally have this feature available...
Sourskittle
Lakeland
Ditto on that.
Glowing device in the window every night prob makes me a target for smash and grab...
Austin
So... About those fan tables in the map switching... Lol
Not likely right now, certainly a possibility down the road.
Yes, the PD settings are close to stock as we ramp in fuel through the CL base table. There are several ways to approach this, but it's up to the calibrator to determine which works best. We've got an update coming that will expand the capability of this table for much better uses.
The auto-off is getting close, it's being tested internally right now to flush out the bugs on the Ford platform. It's made life much nicer in our shop cars so I can only imagine how much it will help you guys out!
Cheers,
-Braden @ COBB
BoostBumps
BoostBumps
Arizona
Thread Starter #25
Cheers,
-Braden @ COBB
Thanks Braden!
I just updated some recent ATR tunes of mine with that minor "Closed Loop Fueling" change made and then reflashed current tune with latest AP firmware update and the time it now takes to reflash is indeed noticeably shorter...very nice....thanks!
And yes....that auto-off can't come soon enough! It will be a much appreciated convenience feature to finally have!
re-rx7
Ardmore
I keep getting hit with a High load cell in my CObb ap. Im on stage 3 OTS 93 map. po61a code
BoostBumps
BoostBumps
Arizona
Thread Starter #28
I think I recall you posting having this issue awhile back... You could send a log of your OTS 93 stg3 to Cobb to look over....
re-rx7
Ardmore
#31
Try to capture it in a log and send it to Braden to review....
Its sporadic. Sometimes it does and sometimes It doesn't. Never pops up on the cluster just when I check with the ap its always lingering in there. Maybe my car is making more tq then the parameters are meant.
BoostBumps
BoostBumps
Arizona
Thread Starter #32
Still worth trying to log during some varied driving conditions...torque and load limits in stg3 are set fairly high to be breaching them and no limits were changed with them from v200 tov201 (I checked)...possibly hit a load limit during partial throttle condition...just an assumption...only way to find out is by logging
[MENTION=555]COBB Tuning[/MENTION] ...Braden would be the guy to speak with about this...
re-rx7
Ardmore
#33
Going for a custom tune soon at Cobb Plano. Calling tomorrow to make appt. I will speak with them about this issue. Might be happening to others without knowledge of it. [MENTION=555]COBB Tuning[/MENTION]
BoostBumps
BoostBumps
Arizona
Thread Starter #34
Your going for a custom tuning? I thought you were in the process of getting rid of your FiST?
http://www.fiestastforum.com/forum/threads/4153-My-Fiesta-ST-for-sale!-Cobb-ATP-FRPP
http://www.fiestastforum.com/forum/threads/4142-TW-part-out-2014-fiesta
re-rx7
Ardmore
#35
BoostBumps
BoostBumps
Arizona
Thread Starter #36
the 2014 gt500 at my dads lot i think is sold. He said someone came in and put a deposit down. My dreams have been dashed. :( either way ill leave the car up for 23k and tune it anyway. Market seems dry right now.
glwts...
Sourskittle
Lakeland
#38
My fuel table in the "cobb features" keeps crashing. I can adjust anything else, but when I try to change the AFR at any rpm, the whole software crashes. Anyone else see this?
Austin
#39
Would you mind sending over additional information on how you are able to reproduce this issue? Does it happen on all map slots, or only a specific one? If you set all tables back to stock (CTRL+K) and modify these tables does the problem still occur? Can you verify the software version?
Cheers,
-Braden @ COBB
Sourskittle
Lakeland
#40
I fixed it by closing the graph at the bottom right. As long as I'm just looking and modding the digits without the graph, it stopped crashing. I'm sure I could replicate it.
Happens on all maps slots and on any rpm when I select the value.
