Hi all…
Finally installing my coil overs (going from Mountune Koni sport setup) . My question is does the rear axle droop differently left to right? I have a 1” variance with the collars exactly the same. I unbolted everything, put it back in and it’s the same. The drivers side of the axle also is harder to get the coil over in. I have a stock rear sway bar, and I did install a rear axle stiffner.Also since I forgot to mention it earlier, the car was on jack stands, axle was drooped. Thanks for the advice.
