CSF 3 Row Radiator
RBYM
California
I’ve read that the stock radiator under performs when it is hot above 90 degrees f and can overheat with spirited driving. I was thinking of upgrading to a mountune or csf radiator. Would this solve those issues?
Saint Pauly
I never had an issue with my FiST overheating with the OEM Radiator. Got a Mountune and never looked back. Any radiator is better than the stock..Triple pass being the best but some of the Dual pass ones available people have had good luck with too. The Whoosh radiator is also a good choice if the Mountune or Mishimoto aren't in stock. [driving]
R
RBYM
California
Thank you.
Burlington, NC, USA
CSF makes the mountune radiator. It works well, but some have concerns about water pump longevity since it’s a triple pass. Mishimoto is single pass and doesn’t create those concerns, but it’s generally shit craftsmanship compared to the CSF/Mountune. I’ve been running Mountune for years with no issue but will install an under driven water pump pulley when it’s time for a new serpentine belt.
R
RBYM
California
Thank you, any good two pass radiators that work better than oem but don’t put strain on the water pump?
Grsemky
Arizona
Is this a single row radiator? How was fitment?
Yeah it's a mishi clone, 3 row radiator... It holds nearly double the coolant, since install I've haven't had any issues overheating even idling at 120⁰ desert temps with ac
I didn't remove the bumper, just jacked the front up enough to slide the Rad out and in from beneath the car, the hardest part was attaching the fan as it does not use the stock style tabs...
sczamun
U.S. Air Force Veteran
Indianapolis
I am thinking of going this route, and I saw that SVT makes tabs to mount the GPI radiator
R
California
Thank you
GA
Thanks for that. That makes my decision easier. Looked all over his site a week or so ago and somehow missed that.
Edit: Damn! Just looked and they're sold out. Wonder if I could make some with some hardware store bar stock.
