Dr.Prutteklutt's Clubsport FiST
San Francisco Bay Area
I placed the Outlet that the Air is going behind the Wheels direct to the Caliper when the Wheels are lined up straight.
Now it looks like this and I am satisfied with it :)
Love the build! I was wondering if you could share where bought the outlet to the wheel wheel from? Looks like a speaker port but I have not been able to locate the correct one.
Also, has this cooling been sufficient for your brakes? I really like the integration into the bumper vs. ducting running from the air dam. Sorry if you have already discussed this in your thread.
Dr.Prutteklutt
Siebengebirge
Thread Starter #246
Hey there!
It is a Flange Connector for a Pond [giddy]
I dont know exacly if it works because since then my Brake Setup changed many Times, but cant be worse than before anyways :)
Dr.Prutteklutt
Siebengebirge
Thread Starter #254
Any weirdness with the ABS sensor?
Cant drive till April soo we will see, but everything under 2 degree Camber is no Problem with the Sensor.
I have 1.9 now so it will be work i think, and every one i know with these Plates here had no Problems at all.
And if not i will grind a little bit of the Surface of the Mounting from the Sensor down to get them closer to work :)
Dr.Prutteklutt
Siebengebirge
Thread Starter #257
Since my last Post in April i did many laps on Track an a few Meets.
I installed a Zunsport Grille to get more Air to my Wagner Intercooler and build a Brake Cooling System.
Put some new Toyo R888Rs on too.
On Saturday i am going to install a Pair of Pagid RSL29 Brake Pads.
Dr.Prutteklutt
Siebengebirge
Thread Starter #258
