E-brake issue - drivers side only
Winter tires means e-brake u-turns on occasion. Just noticed that only my drivers side is locking. Would this be a slide pin greasing issue?
tri-pedaler
Thread Starter #2
Bump - ideas on the e-brake issue?
kivnul
Never hurts to check out the pins. I would compare pad wear in general between the two sides to see if its the same; if not you have a caliper issue. If you can get someone to assist, you could see if the cable is retracting the same on both sides when someone pulls the happyhandle.
tri-pedaler
Thanks. I’ve not done brakes yet as they were new when I got it 10k ago. do we have a traditional cable/drum e-brake? If so checking the cable adjustments sounds like a good starting point
kivnul
Discs all the way around the car. Ill send you a file.
