- Member ID
- #517
- Messages
- 1,437
- Likes
- 315
As I said above, you do NOT need to drop the sub frame to remove the front sway bar.
If you do decide to preform this task on your back ( not recommended).
Then you will only need to remove the two rear most sub frame bolts and only loosen the front two bolts but do not remove them.
The rear of the sub frame will lower about two inches.
This is also the best way to remove the OE down pipe with cat and shields.
There is no alignment of the sub frame on this platform.
So there is no worries just bolt it back up.
If your front sub frame requires alignment then you have bent your car.
You should then seek professional help.
Dave
Dave
