Fiesta ST-2 Engine issues - juddering, misfiring, low on power
Hi,
So my ST has experienced a significant loss in power where I struggle to get past 55mph on the motorway, it has also developed a juddering when both driving and idling. I have taken this to my local garage who have fitted it with a new coil pack thinking that was the issue. When I’ve got the car back it’s still experiencing the same issue as before and the engine warning light is also showing.
I’m a bit lost as to what to do next as I contacted puma speed who have basically advised I will need a new engine if it is only running on 3 cylinders now. Has anyone experienced this type of issue and if so was it fixable or am I going to have to pay out for a new engine which is quoted at about £2500.
Any response I will be grateful for. Thanks in advance
Hi,
A compression check is in order to give you an overall baseline health of the engine. Once you know the individual cylinder compression output you can compare it to fomoco spec and determine if the engine is Bad. Good luck...let us know what you find*
A
Okay, I’ll get a compression test run on this tomorrow and see what output I’m getting from them and take it from there. Thanks for your response
Compression test is a good idea, but it also should be scanned for codes.
