Fiesta ST Backup Camera Intall Guide(Without Damaging your Vehicle)
Spork1569
Fillmore, CA
I was able to do it despite not being electrically inclined at all , like atlantaM3 said there's a ton of good guides online that make it super easy to follow.
Only recommendations that helped me too is using the harness mentioned above and the Canopener tool below which basically does the for scan stuff for you if you're worried about that.
https://www.4dtech.com/ford-backup-camera-programmer-harness-for-ford-vehicles/
NY
I also purchased the 4D harness for my install, but skipped the Canopener tool. Forscan is relatively easy to use (compared to other car programming software) and tons of guides are available.
itouma99
Texas
Did you guys have to wire the red wire that comes off the RCA cable that goes into the 4D harness? This is my first time trying to install a reverse camera lol
Hydancell
UK
#27
I ran the power wire through the rubber grommet by the trunk hinge using a metal coat hanger to guide it, worked great without needing to drill or mess anything up.
