Ford Fiesta ST How to Apply a Wallpaper to your MyFord Touch
Admin1
Dearborn
MyFordTouch Wallpaper Loading Guide:
Step 1: Load your favorite wallpaper images onto your USB drive (drag & drop into the main folder).
Step 2: Insert the USB drive into the USB port in your vehicle (located in the center console, except in Explorers where it is located under the dash).
Step 3: Select the “Settings” button (cog wheels on main screen).
Step 4: Under the Settings menu select the “Display” button.
Step 5: In the Display menu select “Edit Wallpaper”.
Step 6: Select “Add”. Then from your USB drive select which photos you would like to import. This will not set the images as your background just yet, it will only copy the images onto your MFT system.
Step 7: Once the images have been uploaded, hit the back arrow and highlight the image you would like to use as your wallpaper and hit “Save”.
Step 8: Select the “Home” button and your saved image will now appear!
[video=youtube;DRHuXQk5vnc]https://www.youtube.com/watch?v=DRHuXQk5vnc[/video]
