I have been having an intermittent issue with my 2016 FIST with 51K miles where the car bucks and cuts power when at WOT (most often when going uphill). After a lot of data logging and diagnosis, I think I've narrowed it down to a fueling issue since my fuel pressure drops from around 2000psi to as low as 35psi when the issue occurs. Under the advice of some people on Reddit, I have replaced the HPFP cam follower and the low-side FP sensor but still the issue persists. I am feeling pretty confident at this point that it is the HPFP causing the issue since my data logs show the low-side pressure staying pretty consistent (within 5-10 psi of desired) whereas the high-side pretty consistently shows pressure dropping far below desired every time the issue occurs. Before I blow $180+ on a new HPFP I want to get some advice from people on here to see if I'm on the right track. I will attach a few data logs as well as a video of the issue in case anyone thinks I'm way off and wants to give their two cents.
Below are the links for the data logs
https://docs.google.com/spreadsheets/d/1wyZQfKwypAZ7hUAg44uzeqNfhOsM-y9yKc55UkkvvXE/edit?usp=sharing
https://docs.google.com/spreadsheets/d/1GIM2FKR7OJA6mdPtBTOmrX5PatuimNc1Q-12ED9DNvA/edit?usp=sharing
https://docs.google.com/spreadsheets/d/13HQCp2jc5SjSZv2LwdEfyWaMCZ7yfO20A-NMUBTCdao/edit?usp=sharing
https://docs.google.com/spreadsheets/d/1rSHscHBffMWaiyH_wYFhLshbZjo5BEHYpzg4c9u4CCg/edit?usp=sharing
