Gauging interest in a run of budget big brake kit brackets?
Are you interested in a set of brake brackets?
  • Hell Yes, I’ve got $400 burning a hole in my pocket
    Votes: 11 50.0%
  • Likely someday, but I’m not ready to put money down
    Votes: 9 40.9%
  • Nah, I’m fine with but this looks cool
    Votes: 2 9.1%
  • WTF?
    Votes: 0 0.0%
  • Total voters
    22
Bedford, IN
#44
Wish list to help others.
Update google doc with reference to front (instead of potentially guessing rear) 986 brake calipers, caliper part numbers (EDIT- they're on page 7), link to whoosh 280mm rear brackets.
https://whooshmotorsports.com/colle...cket-kit-for-280mm-rotors-2014-2019-fiesta-st
A print out that we can use to check wheel fitment that has a scale on it to verify size. I would make one, but haven't purchased calipers or rotors yet, so cannot verify sizes. Something like this. I think I'm right on the line about whether or not my wheels will fit with spacers. Having the easy print out should help be able to quickly check other wheel sizes.
https://www.brakes-shop.com/brakepe...zFdxUFTCz-dZTluN0j9OHtBAKvQNIhWwboPQDEkYrTHD3
Dialcaliper
Dialcaliper
San Francisco Bay Area
Thread Starter #45
Thanks for the feedback.
I’m working on a template model and I’ve got one that’s representative to within about 2mm based on some back and forth with Konig’s technical support. Their Dekagram CAD model vs my CAD model shows 1mm clearance, my actual on-car measurements show 3mm. Trying to refine it a bit closer as the clearances are quite tight.
Dialcaliper
Dialcaliper
Thread Starter #46
Dialcaliper
Dialcaliper
Thread Starter #48
Currently rebalancing the Heliograms to avoid wheel weight contact with the calipers.
View attachment 68596 View attachment 68597
When you reverse the crossover tube, you need to switch tubes between calipers and it should bend the other way.
Also, it seems like you might have the caliper oriented the wrong way on the wrong side - the pocket the crossover tube used to sit in should be “up” and the tube moved to the opposite side of the other caliper.
More details on page 9 (reversing tubes) and page 12/13 (caliper orientation with small/big piston) of the instructions.
Looks like I could put another picture in the instructions. Here’s how mine look:
Dialcaliper
Dialcaliper
Thread Starter #49
Other than the orientation issues with the tube, looks like it’s coming together? How is the fitment with the Heliograms? Did you end up needing a spacer? The area the Konig rep thought would be the closest clearance was right near the hub of the wheel
Irvine, CA
#50
Been putting in 70+ hour weeks at work recently so have had a shop tackle a number of things for me. I just happened to show up yesterday and took some photos of the work. I knew something was off, so thanks for the help.
Wheels were on and it looked like it cleared the hub, but I’m not 100% sure, may still need a spacer. I will know more once the rest of the work is completed later this week.
Dialcaliper
Dialcaliper
Thread Starter #53
Recently, I learned that if you choose to use silicone dust boots, some brake greases (specifically silicone based greases) are not compatible with them. Basically silicone eventually dissolves silicone rubber due to how it’s made
Silicone grease is fine with most other rubber types. If you choose to use the silicone boots, don’t use any grease on the pad-backs.
Likewise, also avoid petroleum based greases with silicone.
Edit: seems like “synthetic” brake lubes are also oil based and maybe not safe.
https://racingbrake.com/internal-fit-high-temp-blue/?page=2
https://racingbrake.com/black-or-blue-boots/
Dialcaliper
Dialcaliper
Thread Starter #54
The only things I’ve found so far that might be safe with silicone rubber dust boots are certain moly pastes that have no or minimal organic binder. Maybe certain fluorinated or Krytox greases, but those are fairly expensive.
Loctite LB 8012 moly paste (not to be confused with anti-seizes with similar numbers) seems like a cantidate as it contains only tiny amounts of mineral solvents. I might give it a try once I clear out the synthetic lube I’ve been using (oops!)
Dialcaliper
Dialcaliper
Thread Starter #55
Just bumping this to see how things are going for everyone with installs. Also, if anyone’s confirmed either other wheels that work or wheel/spacer combos
Dialcaliper
Dialcaliper
Thread Starter #56
Picked up a set of 16x8” Konig Heliograms as track wheels, and confirmed as above that they have boatloads of spoke clearance (more than the Dekagrams)
San Diego
#59
Anyone test this kit with Enkei RPF-1s in 16? I might be interested in a kit during the next run. (If you make another run of them)
Dialcaliper
Dialcaliper
Thread Starter #60
Anyone that’s in (or passing through) the Bay Area is welcome to contact me to meet up for a test fit as time permits
I’m contemplating arranging another batch as a group buy later this spring/summer when things cool down at work
