Good article on fire extinguisher, featuring a FiST!
I hope not, but depending on the event and/or organization, they may be required to pass the technical inspection.
Just wanted to make sure... I've owned some sensitive Tinder box's in my life and still do...
kivnul
U.S. Army Veteran
Deer Park, WA
I attest to the Motorstate bracket, works great. Since the extinguisher is somewhat suspended over the floor, it can vibrate a bit if your ears are sensitive to that sort of thing. If so, a couple of rubber bands can hold all the wiggly bits of the extinguisher itself steady to keep things quiet.
Edit: Looks like he has not been online since June of 2020.
Wichita, KS, USA
So They say they start on Fire easily?
They did have a service bulletin for potential cylinder head cracks developing leaking oil on the exhaust manifold with low coolant levels. Something to do with the ect sensor I believe.
