Gtx2860 maxd out
pwnall1337
Vendor
San Antonio
Not that I know of. But they do work for mountune
what rpm are you hitting full boost at? Seems like your power band matches my old power band before we adjusted the wastegate to 18 psi. Getting on the throttle before boost causes engine load and timing is pulled. Even at 18 PSI wastegate I still pull timing every now and then from 3rd gear going wide open throttle before boost hits.
Knoxville
And I'll be the first to say. Ditch the OE boost control crap and go tru boost. Way better spool and consistency
Knoxville
#31
I'm shooting for more. My goal is to do deadhook numbers or better on the the bolt on gtx2860r.
Simi Valley
#32
GTX2860 will flow 42lb/min and is good for 420 hp at 28-30 psi. Without fuel and running 28 psi your not maxing a 2860 on a fiesta.
