HELP!! car won't start, battery is charged and the ignition tuns on but no crank.
San Luis Obispo
Hello,
Recently I have purchased a 2014 Fiesta ST from Copart. The car will not crank over, but with a fresh battery the car will enter the on position and relays will click like the car is trying to start, but no crank. The only mechanical issues that I have identified are a broken MAP sensor and wiring, broken fan shroud, and a torn evap line. I believe that I heard the fuel pump priming as well. I have the clutch pushed in and brake engaged. Please if any techs know what is going on or can help me get it to crank any help would be appreciated.
Thanks!
CanadianGuy
Southern Ontario
Bad starter? Bad starter wiring? And 2014 have a known issue that the ground of the battery is not secure enough to the body and with corrosion will limit amperage.
L
San Luis Obispo
Update: cleaned negative ground and replaced fob battery, still no start. Clutch switch is still functional, and starter will spin when solenoid is jumped but will not engage the engine. Had battery tested and it came back as bad. Will replace tomorrow and update.
L
San Luis Obispo
Update 2: replaced battery, problem persists. Car is throwing a P007B and P0113 code, presumably because of the map sensor. I'm going to rep;lace that nest, but i don't think it's likely that it is the issue.
San Diego
Wow. It sounds like you really bought into a project. I hope you knew this going in and the price was right.
L
San Luis Obispo
I knew it didn't run, but I didn't think it was going to be this tough. I bought it cheap so there's plenty of money that I can invest before I'm underwater.
San Diego
Yeah, some time ago a friend bought a barely running car for pittance because the owner assumed the worst and didn't want to fix it. It turns out one spark plug had the electrode finger broken off. So replacing a dollar spark plug fixed the car. You never know.
L
San Luis Obispo
Update: cleaned the engine to body ground, no change. looking through the notification log in the settings, I found a warning from a while back that said "Immobilizer malfunction. Service now!". Starting to think that the immobilizer is causing the no start. Once the body and suspension repairs are squared away I will tow the car to the dealership to get reprogrammed.
L
San Luis Obispo
Update: MAP sensor was installed last night, still no start, same symptoms. I seem to have misplaced my code reader, but i will pull codes when I find it again
Ponce
Remember that I was having that same problem? Well in the dealership they changed the clutch switch sensor and apparently the problem is fixed. I will post any update if anything changes. I'm at work right now, later I will post the warranty bill with the details.
L
San Luis Obispo
Problem Solved. The connector on the front left side of the car was not fully engaged, once the lever was closed the car started right up. Additionally, I highly recommend the factory service manual, it has a 26 step diagnosis guide that made this much easier.
CanadianGuy
Southern Ontario
Can you elaborate connector on the front left side?
Ponce
The clutch switch sensor didn't solve the problem, this morning the car didn't turn on. What's that front connector? Where is it located?
PunkST
Menasha
I am also curious. Ive had an intermittent no start since my car got repaired from a deer hit.
Armenia
Hello,
Thanks!
Mini Cooper Brake pads Replace Dubai
Background: Car was 100% charged / about 68k miles / 4 years. / Expired warranty
Out of nowhere, it cannot start at all this morning. No power what so ever. Everything cannot be turned on at all including back trunk and front cover. Need to towed the car to a local dealership for diagnose. Before it "died" , I saw a transmission malfunction alert on the dash board. (This is out of the blue as I just had my routine checkup 3 months ago and car ran smoothly yesterday).
Anyone experienced this before???
