[solved] Help! Front blinker gremlins
Backstory: '15 FiST that worked fine as stock. I wanted to "upgrade" to LED front markers so wound up w xenondepot xtreme LED blinkers w resistors. Installed them but noticed that the left blinker would never blink if the headlights were also running. It would appear to just stay lit. The left blinker would work normally if the headlights were off. On close inspection, the left blinker would very subtly flicker a few lumens brighter to the 'beat' of the blinker stalk activation, but it was so subtle that no driver could ever tell it was happening...
I got tired of confusing folks on the road w my non-functional left blinker, so wanted to swap back to stock incandescent.
Swapping back the bulbs and removing the resistors has me confused. Things I'm noticing now:
- unlocking the car, the left blinker blazes REALLY brightly while the right unit runs very dim
- locking the car, emergency flashers both lights work equally and as intended
- activating turn signal to the left causes hyperflash and no blinking of the bulb
- activating turn signal to the right is normal
I DID notice both sockets for the blinkers were 'loose' in that they would unseat and pop forward a bit into the housing and one connector tab for the right unit was slightly bent.
Anybody have similar issues before? There are 3 connections per blinker, are they position dependent? I noticed I could insert the blinker lights in different angles of 1/4 turn but some variations would not fully seat the bulb...
Wondering if to fix I need to replace both headlight units entirely....![Angry [:(!] [:(!]](/images/smilies/icon_smile_angry.gif)
thx!
thx!
