Help! Low boost - new sound
Oklahoma City
With the mishimoto charge pipes you're going to notice less of a "climax" with the pressure drop of the larger diameter tubing.
Sent from my Pixel 2 XL using Tapatalk
Lawrence
Silly question, did you accidentally switch your map slot to eco mode? Meaning WG boost only (~4-8psi)?
T
Austin Area
Thread Starter #30
No. I’ve tried it on custom tune, Cobb OTS and with AP unmarried. Drives with less power than stock. Maybe it’s time to rebuild the turbo...
Saint Pauly
#33
I would think the dealership would have caught a spent turbo, but who knows. Are there any items I can log with the AP to verify?
Best way to check is to take the hose off the in inlet and move the compressor from side to side to check for play and move it in and out and even spin it. Look for oil also in the inlet hose....
T
Austin Area
Thread Starter #35
Man that sucks... what mods are you running? Didnt see a list anywhere.
Basically Mountune MR 230 without the downpipe, Mishimoto hard pipes, FSWerks short shifter, aluminum flywheel, Spec stage 2 clutch, AP with Mountune tune, carbon fiber shift knob
Lawrence
#36
Another silly question, have you inspected all clamps, elbows, piping and welds from your cold side? I have heard a few issues in the past of:
COBB charge pipe cracked weld on support bracket.
Couplers blown off due to clamps loose after a tune.
Welds cracked on support flanges for intercoolers.
All of these scenarios would give you reduced boost, a loud hissing sound and may not throw a code. After everything else and now this last bit of advice, I am at a loss. Good luck to you! Let us know what you find.
T
Austin Area
Thread Starter #37
Didn’t check the intercooler. I’ll do that as well.
Quisp
Davenport
#38
Try diverter valve. Mine wouldn't go over 16psi and that was the culprit.
T
Austin Area
Thread Starter #39
So my son hit a dip pretty hard... and all of a sudden the boost is back. I’m at a complete loss. Any guesses?
