HELP!!.
PunkST
Menasha
Flashing back to stock and my car failed to reflash. Its due in at ford tomorrow. Im trying to recover it now.
PunkST
PunkST
Menasha
No it failed to return to stock. Still have battery and the AP is good. Never lost communication.
Says car is in recovery mode. And its totally immobilized.
PunkST
PunkST
Menasha
Could it have blown an antitheft system fuse?
Do leave things plugged in all the time to it like a phone charger? If so I see a lot get blown due to that....
PunkST
PunkST
Menasha
Idk im trying to find the fuse layout. Would that have cause the issue??
PunkST
PunkST
Menasha
Thread Starter #12
I literally just tried to go back to stock to be able to bring it into ford. It says it fails to reflash and it goes into recovery mode. I have warnings for the immoblizer, steering, hill start assist. Everyting comes on but it wont friggen start
PunkST
PunkST
Menasha
Thread Starter #13
Earlier this year yeah with no issues then.
PunkST
PunkST
Menasha
Thread Starter #15
Has never had a problem at all. It was working 100% fine when i pulled into my driveway.
Are you using a battery maintainer when flashing? Maybe the battery voltage is throwing things off if its too low?
slopoke
Livermore
IIRC, wasn't there an issue of not having the current firmware update and having failures when trying to unmarry the Accessport?
PunkST
PunkST
Menasha
Thread Starter #19
If so then im totally fucked. I cant get anything to happen. I looked at all the fuses and none seem blown.
Fully charged battery is 12.6 volts and 2.1 volts per cell and there is 6 cells in most batteries. So id say that could be an issue.....
