Quick note, you are actually pulling fuses F11 and F2 in your photo. I'm installing my kit right now. Also, looking at the Ford instructions, they say to use a low amp rated fuse with power only when ignition is on for auto dimming (Operation 23) and a low amp rated fuse with full time power for homelink(Operation 28)
I don't see the need to use the 20 amp fuse for the windshield wiper (F11). I would use lower amp wires. I'm already using F11 for my escort radar detector, so I'm using F15 for autodimming (on when ignition is on) and F16 for the homelink (on all the time). On my kit (4L3Z-17700-B) the Black wire with the white stripe is the autodimming wire, the Black wire is the homelink wire.
F15 is the wiper switch and F16 is the Electric exterior mirrors and power windows.
There is a writeup on this method (useful when you have both a autodimming/homelink and a radar detector) here
http://www.fiestast.org/forum/fiesta-st-electronics/897-gentex-mirror-install-homelink.html
I am going to monitor temps inside of my cabin, since the FiST already has an external temp monitor and the air conditioner only has a set temp.
One last thing. There is a white clamp on the plug that goes into the mirror. You need to pull up on this clamp, then insert the two temp wires, then push the white clamp back down.
Also on my plug there were two wings on either side of the locking tab. These needed to be clipped with a wire cutter before the plug would fit into the mirror. Don't know why this was not in my instructions, but it would not fit without cutting those wings. See instructions, opn. 14. This shows the plug with the wings.
