How to fix side vents trims?
Lausanne, Switzerland
At some points, these things fell off on both sides. Does anyone know how to fix it? They do not hold in place and I was thinking to use two-sided tape, but I am afraid that the hot air will melt the glue and they will fall off again. Any ideas?
If the air coming out of there was hot enough to melt glue....Do you think your dash would stand a chance of not melting.....I don't think so. Get the 3m 2 sided tape. NOT knock off 2 sided tape though. Clean the surface and adhere them together. It will adhere better in the heat than in the cold keep that in mind. Good luck!
