Ideas on Fault Problem ?
After driving several hundred miles onn vacation without issue, I went to start out on the final leg home this am when I ran into a probleM. After running just about a minute or so, I went to turn a corner and the car stalled. Thinking it was just a momentary issue, I pulled over and restarted the car, all seemed fine. But a hundred feet later, I turned another corner and I abruptly slowed. I realized that I slowed because the engine was not responding to my gas pedal. Went though the restart routine several times to get back to my starting point. No tools except for an adjustable wrench, I managed to get the battery cables undone thinking maybe I couyld clear the fault. Only made it worse, after reconnecting the cables, car refused to do anything, said I was in Immobility Mode, get service immediately. Getting it towed to a Ford dealer, hoping this has nothing to do with my aftermarket tune, Pullede the Accessport to give them access to the service port. Anyone have this ecxperience ?
Cneu
I would have tried to pull logs while it was still running.
You'll need to get a OBD reader and dig into it. Logs/fault codes are what you'd need here.
I doubt it has anything to do with your tune.
It only happening in corners makes me wonder if something is clogged or you have some kind of evap situation going on? I'm sure others will have more input. My starting point would be the fuel system, then intake, throttle, etc.
edit: lol for comedy I asked AI. It pointed me to this thread, https://www.fiestastforum.com/threads/engine-turned-off-twice-while-driving.26553/ and gave me this answer:
Stalling while cornering in a Ford Fiesta could be caused by issues such as a faulty throttle body, problems with the fuel system, or a malfunctioning mass air flow sensor. It's advisable to check for any diagnostic trouble codes and inspect these components to identify the root cause.
S
Thank you so much for that input. I would have pursued this further on my own but I’m still 150 miles from home. Interesting that the throttle body responded on restart but went dead after cornering, especially given the AI summary answer. I’ll be sure to report on what gets it resolved.
Throttle body* Ill bet buy one from Amazon with the OEM Bosch # off the part. It's what i did ...it was like $70*
https://a.co/d/8JqTVSf
How did it die? did it just quit, same as turning the key? did it sputter out? did it like surge then die? Either throttle body or fuel pump. If no check engine light i lean to fuel pump. The throttle body has dual pots in it that confirm its location vie bias signal. if they vary for even a spilt second its sets a code. if it cant move to where its trying to go it sets a code. a fuel pump can die with no feed back to system other then no fuel pressure.
S
The first time, the engine stalled. On restart, it would behave normally until I turned a corner (in either direction) then slow down to engine idle with no pedal response. Being 200 miles from home with no tools or code reader, I had it towed to the nearest Ford dealer. After several days in the shop, they called to say a module had failed (the service agent did not know the name of the module but said it resides under the passenger seat), $1700 parts and labor to fix it, wanted a $500 deposit to order the part. Clearly this is a ripoff but I’m still away from home (fortunately, have a place nearby I can stay; thank god I’m retired with no job issues !) And I need my car, so I bit the bullet and ordered the part. Suppose to be in and fixed Wed or Thur.
S
Well, got the car back, charged the estimate, $1700, delivered on time. I was told before they ordered parts that a module had failed. The service rep said she did not know the name of the module but that it resided in the passenger seat. When she called me to pick up the car, she said it was a faulty OCSM module (had no clue what that was at the time). Reading the invoice (I’ll post it, I’d appreciate other interpretations) it sounds to me like the tech cleared the fault codes and, my interpretation is that that solved my immobility mode issue and my original throttle response issue. But then it appears he discovered a faulty OCSM module (Occupant Classification Safety System). When I looked up the listed part number, it says that the part is a seat pad ! Now, I’ll give them the benefit of the doubt for now and think that the OCSM may be part of the seat pad and is not sold separately. But that also indicates to me that it is not a complex module (my guess is that it probably merely detects the presence of a passenger or not, activating the air bag if it’s occupied). So, thus far, my complaints revolve around the facts that, if I am correct, they should have explained that the failed OCSM was an incidental finding and given me the choice as to whether I wanted to spend $1220 for a seat pad/module (they charged me for hours of labor @ $180 per). This may be a case of bad communication (deliberate or not to increase revenue); or, it could just be deliberate blatant dishonesty, not the first time I’ve encountered that with my FiST’s. Any feedback would be appreciated.
