Intake crossover tube yellow O-ring
DangerMouse
Rockford
Yay me the yellow O-ring that plugs into the crossover ripped. Does anyone know if you can get a new O-ring or do I need the whole new hose? I dont even know what's it's called so I couldnt find anything. Thanks!
DangerMouse
DangerMouse
Rockford
Thread Starter #2
I found the replacement part on Tasca for $137 Evap emissions system line C1BZ6A664D. for 2016 and up. 2014-2015 used a different style part # C1BZ6A664A. I can get it on eBay for $30 and steal the O-ring from it. I would rather find a replacement o-ring for cheap, but I’m not sure if I can find the correct size and make sure it doesn’t leak. Anyone have any luck with this? I think what happened is I was left it unplugged over night while working on it and the gasket swelled. Then when trying to plug it back in, it ripped.
DangerMouse
DangerMouse
Rockford
Can you try a junkyard?
No fiesta st locally and I'm worried with it being used that the o ring will be bad anyway. I know a few people have had this problem in the past but I can't find anything how they resolved it. Would be nice to find a replacement and have a couple on hand. I'm going to call the dealership tomorrow and see if they can get the o ring.
Jabbit
New England
Might buy one of those large o ring assortment packs from Amazon
DangerMouse
DangerMouse
Rockford
I actually didn't think of that and I get everything on Amazon these days. I found some that are oil and fuel safe. Fingers crossed one fits. I'll update when they get here.
SFV, So.Cal.
That connector is used on many Fords.
I also suggest you check Wrecking Yards, maybe a Pick Your Part and look at other Fords.
CarGuy
Daytona Beach, FL, USA
Post your results.
Franklinville, NC, USA
Check with Justin he has a glorious fiesta graveyard. When I visited him he had 5 or 6 and probably has bought that many since then. Here is his SN on here.
SVOFANATIC
DangerMouse
DangerMouse
Rockford
SVOFANATIC
Thanks, I’ve bought from him before on facebook, but I’m worried that getting a used one will end in the same result. I ordered a kit on amazon, will be here Tuesday.
DangerMouse
DangerMouse
Rockford
O-rings came in from amazon. I should have purchased the larger kit but i really don’t need 800 o-rings. Let alone the 300 I received. The one that I used is a 17mm x 2mm thickness. The next size up was a 17mm x 3.5mm. That was too thick. Ideally I would like a 17mm x 2.5mm or 3mm. The larger kit does come with a 17mm x 2.4mm o-ring. The one i used sits inside the groove and doesn’t really offer much to seal. Good news is, there is another o-ring on the connector that does most of the work and it was not damaged. I have been driving it and wasn’t getting any check engine lights but I’m not sure if it would even cause a cel or not.
DangerMouse
DangerMouse
Rockford
Well I broke down and bought the other o-ring kit. The first kit measured by inside diameter, this kit was outside diameter. I went with a 23mm OD x 2.4mm thick o-ring. Fits perfect and was much easier to install. Matched up with the original broken o-ring it’s Identical. So if anyone has this issue, thats the size you need.
