- Member ID
- #1508
- Messages
- 102
- Likes
- 14
This is a two stage question:
First, just how accurate is the torque read out on the AccessPort? Is it a reliable judge of performance increases as it pulls from the same parameters each time, it should have consistent results, regardless of accuracy, it should show at least a relationship if all other conditions are similar.
Second, I've heard the stock ecu targets torque rather than boost, and I've seen a bit of a wall in some cases of around 250ft/lbs. I can only assume it retains that trait when reflashed. I've also read that it limits torque in the lower gears to aid traction. My own use of the AP3 on a mostly stock car shows lower numbers the lower the gear. Is this actually limited or just a function of how the AP3 judges torque?
This is my most recent pull. I got to these torque numbers going down the interstate in 6th gear. Previously, I would hit 230ft/lbs in spirited driving (lots of WOT).
Just trying to get a reason for my findings. The car is an absolute blast and I know the gauges are no replacement for an actual dyno, it would just satisfy some curiosity.
Thanks to everyone who reads and responds.
