So the dealer gave me a key fob without the tiny metal ring...
I can't seem to find a replacement anywhere. A larger normal sized key ring won't fit in the small cutout opening. Any ideas? Anyone experience this?
After first removing the cover to gain access to the metal key.
Next split the Fob as if you were changing the battery.
Then you can tilt the end up to remove the ring, or in your case to install one.
